Editor > Add > Data Display
Use to add or remove data display types from the active graph.
Data Display
Bars: Check to display bars that join each data value to its base.
Symbols: Check to represent each data value with a symbol.
Connect line: Check to connect the data values.
Project lines: Check to display lines that project from each data point to its base.
Apply attribute assignment variables of current displays to added displays: Check to use the same attribute grouping variables for the added displays as are used for the current displays.
