Editor > Add > Data Display
Use to add or remove data display types from the active graph.
Data Display
Median confidence interval box: Check to display a confidence interval box, which shows the 95% (default) confidence interval for the median.
Interquartile range box: Check to display an interquartile range box (default). The box bottom is at the 25th percentile and box top at the 75th percentile.
Range box: Check to display a box that extends from the minimum data value to the maximum data value.
Outlier symbols: Check to represent each outlier with a symbol.
Individual symbols: Check to represent each data point with a symbol.
Median symbol: Check to represent each median with a symbol.
Median connect line: Check to connect the medians of grouped plots (only visible if you have categorical variables in the boxplot).
Mean symbol: Check to represent each mean with a symbol.
Mean connect line: Check to connect the means of grouped plots (only visible if you have categorical variables in the boxplot).
Apply attribute assignment variables of current displays to added displays: Check to use the same attribute grouping variables for the added displays as are used for the current displays.
