Editor > Add > Data Display
Use to add or remove data display types from the active graph.
Data Display
Interval bar: Check to display a confidence interval bar. The default confidence level is 95%.
Bar: Check to display bars that join each mean to its base.
Individual symbols: Check to represent each data point with a symbol.
Mean symbol: Check to represent each mean with a symbol.
Mean connect line: Check to connect the means of grouped plots (only visible if you have categorical variables in the plot).
Median symbol: Check to represent each median with a symbol.
Median connect line: Check to connect the medians of grouped plots (only visible if you have categorical variables in the plot).
Apply attribute assignment variables of current displays to added displays: Check to use the same attribute grouping variables for the added displays as are used for the current displays.
