Editor > Add > Footnote
Use to add a footnote to the active graph. After adding a footnote, you can change its attributes and alignment (see Editing Labels Overview).
Footnote: Type a footnote, which appears at the bottom left of the graph. Each additional footnote goes below the preceding footnote.
