Add gridlines
overview
    how to
Editor > Add > Gridlines
Use to add gridlines to the active graph. Not all items are available with all graphs.
Dialog box item
Show gridlines for: Check to add gridlines at the specified locations.
Z major ticks
Z minor ticks
Y major ticks
Y minor ticks
X major ticks
X minor ticks
Note
If the active graph has both primary and secondary scales, this dialog allows you to add gridlines by scale as well as axis.
