Tools > Toolbars > 3D Graph Tools
Use this toolbar to rotate 3D graphs and 3D surface plot lighting and to resize the data region. By default, this toolbar only appears when a 3D scatterplot, 3D surface plot, or 3D wireframe plot is active. To hide this toolbar, choose Tools > Toolbars > 3D Graph Tools.
Toolbar item |
Use to... |
Rotate the graph clockwise or counterclockwise about the x-axis. |
Rotate the graph clockwise or counterclockwise about the y-axis. |
Rotate the graph clockwise or counterclockwise about the z-axis. |
Rotate all 3D surface plot lighting clockwise or counterclockwise about the x-axis. For additional lighting controls, see Edit Surface - Lights. |
Rotate all 3D surface plot lighting clockwise or counterclockwise about the y-axis. |
Rotate all 3D surface plot lighting clockwise or counterclockwise about the z-axis. |
Increase or decrease the size of the 3D box. (To zoom the graph window in or out, choose Editor > Zoom.) |
Return the graph to its original position and zoom. |
Return all lights to their original positions. Also returns other surface lighting options, except brightness, to their original settings. |
Tip |
When rotating a graph or graph lighting, click to rotate in small increments; click and hold for continuous rotation. |
