1 Choose Editor > Add.
2 Choose the item you wish to add.
3 Depending on the item, you may be prompted to provide more information. Do so and click OK.
1 Right-click the graph.
2 Choose Add and select the item you wish to add.
1 Select an item from the drop down list of addable elements.
2 Depending on the item, you may be prompted to provide more information. Do so and click OK.
