1 Using , the
selection tool, select the objects you want to affect.
2 Choose Editor >Annotation > Rotate Left, and choose the angle you want from the submenu: 15, 30, 45, 60, or 90 degrees.
If you want to specify an angle not on the menu, choose Other, enter a value, and click OK. See Rotate - Other.
