Each graph has an icon on the graph-window title bar that indicates its update status.
Icon |
Indicates the graph is... |
Because... |
Current |
You manually updated the graph, have specified Minitab to automatically update, or haven't changed the graph data. |
Not current because the data have changed |
Minitab is waiting for you to manually update the graph (see To manually update graphs). |
On hold because Minitab cannot update the graph |
The graph is set to update automatically, but Minitab cannot update the graph. For example, you may have unequal column lengths or unacceptable data values. Minitab waits until the condition is resolved and then updates the graph. |
Not current and not eligible for updating |
It is part of a layout, not a core graph, or cannot otherwise be updated. |
