Area Graph - Options
     how to      see also
Graph > Area Graph > Area Options
Use to switch stacking order between column order and variation order.
Variable Order
Column order (first on top): Choose to stack the variables in the order they are entered in the dialog box, with the first variable you enter on top of the stack.
Variation order (largest on top): Choose to stack the variables by the degree of variation, with the variable demonstrating the largest variation on top of the stack.
