Graph > Individual Value Plot
Use to assess and compare sample distributions by plotting individual values for each variable or group in a vertical column, making it easy to spot outliers and see the distribution.
If several points have the same value, by default Minitab offsets them symmetrically from the center, so that each identical point is visible. |
One Y: Choose one of these options to display a separate graph for each column.
Multiple Y's: Choose one of these options to display multiple columns of data on the same graph.
