As a quality control engineer for a camera battery manufacturer, you want to examine the relationship between flash recovery time (minimum time between flashes) and the voltage remaining in a camera battery. You create the three types of marginal plots to look at the distribution of each measurement.
With histograms 1 Open the worksheet BATTERIES.MTW. 2 Choose Graph > Marginal Plot. 3 Choose With Histograms, then click OK. 4 In Y Variable, enter FlashRecov. 5 In X Variable, enter VoltsAfter. 6 Click Labels, then click the Histogram Labels tab. 7 Check Label histogram bars with y-value, then click OK in each dialog box. |
With boxplots 1 Open the worksheet BATTERIES.MTW. 2 Choose Graph > Marginal Plot. 3 Choose With Boxplots, then click OK. 4 In Y Variable, enter FlashRecov. 5 In X Variable, enter VoltsAfter. Click OK. |
With dotplots 1 Open the worksheet BATTERIES.MTW. 2 Choose Graph > Marginal Plot. 3 Choose With Dotplots, then click OK. 4 In Y Variable, enter FlashRecov. 5 In X Variable, enter VoltsAfter. Click OK. |
You can look at the scatterplot as well as the distributions of both x and y using histograms, boxplots, or dotplots.
Tip |
To see information for an individual symbol, box, or bar, hover your cursor over it. |
