Graph > Matrix Plot > choose Matrix of plots - Simple, With Groups, or With Smoother > OK > Matrix Options
Use to control the matrix display and variable label placement for a matrix of plots. After you create a matrix plot, you can control the placement of ticks and change plot margins (see Edit Matrix Plot Options).
Matrix Display
Full: Choose to display the full matrix.
Lower left: Choose to display the lower left portion of the matrix.
Upper right: Choose to display the upper right portion of the matrix.
Variable Label Placement
Diagonal: Choose to display the variable labels along the diagonal. (default)
Boundary: Choose to display the variable labels along the boundary of the matrix.
