Example of a simple each y versus each x matrix plot
    interpreting results      session command
You collected data on resting (Pulse 1) and post-workout (Pulse 2) pulse rates from a group of college-age students and want to examine the relationship between these readings and height and weight. Only the pulse rates of those who completed the workout are included (Ran = 1). Because you are only interested in the relationship between the pulse readings and the other group of descriptors, an each y versus each X matrix plot is most appropriate. Create a simple each y versus each x matrix plot.
1    Open the worksheet PULSE.MTW.
2    Choose Graph > Matrix Plot.
3    Choose Each Y versus each X - Simple, then click OK.
4    In Y variables, enter Pulse1 Pulse2.
5    In X variables, enter Height Weight.
6    Click Data Options, then click the Subset tab.
7    Under Include or Exclude, choose Specify which rows to include.
8    Under Specify Which Rows To Include, choose Rows that match. Click Condition.
9    Under Condition, enter Ran = 1. Click OK in each dialog box.
Graph window output
Interpreting the results
It looks like there may be a relationship between weight and the post-workout pulse rate. You might try adding smoother lines or using categorical grouping variables to refine your example.
Tip
To see the row number and x- and y-values for a symbol, hover your cursor over it.
