Graph > Probability Distribution Plot > choose Vary Parameters or Two Distributions > OK > Multiple Graphs
Controls the placement and scales of multiple probability distribution plots. After creating a graph, you can:
Show Distributions
Overlaid on the same graph: Choose to overlay graphs on the same data region. See Overlaying Graphs.
In separate panels of the same graph: Choose to display each graph in a separate section of the same page. See Paneling Graphs.
On separate graphs: Choose to display each graph in its own graph window.
Same Scales for Graphs: Only available when you choose In separate panels on the same graph or On separate graphs.
Same Y: Choose to use the same y-axis scales for all graphs.
Same X: Choose to use the same x-axis scales for all graphs.
