Probability Plot creates an estimated cumulative distribution function (cdf) from your sample by plotting the value of each observation (including repeated values) against its estimated cumulative probability.
Estimated cumulative probability is calculated by one of the following formulas, according to what is selected in Tools > Options > Individual Graphs > Probability Plots (the default is median rank). For each formula, let n equal the number of observations and i equal the rank-order of each observation such that i = 1 for the smallest value and i = n for the largest.
Method |
Formula | ||
Median Rank (Benard) |
Mean Rank (Herd-Johnson) |
Modified Kaplan-Meier (Hazen) |
Kaplan-Meier |
The fitted distribution line represents the cdf for the chosen theoretical distribution with the indicated parameters (either estimated or historical). If you do not provide historical parameters, Minitab will estimate the parameters using least squares estimation (normal or lognormal distribution) or maximum likelihood estimation (other distributions).
The y-values (and in some cases the x-values) are transformed so that the fitted line is linear. Tick labels, however, remain consistent with the untransformed values. Thus, to the extent that the chosen distribution fits your data, the plotted points form a straight line.
The table below shows the transformations used for each distribution.
Distribution |
X-coordinate |
Y-coordinate (score) |
Normal |
data |
Lognormal |
ln(data) |
3-parameter lognormal |
ln(data - threshold) |
Gamma |
ln(data) |
G-1(p), k |
3-parameter gamma |
G-1(p), k |
Exponential |
ln(data) |
ln(-ln(1 - p)) |
2-parameter exponential |
ln(-ln(1 - p)) |
Smallest extreme value |
data |
ln(-ln(1 - p)) |
Weibull |
ln(data) |
ln(-ln(1 - p)) |
3-parameter Weibull |
ln(-ln(1 - p)) |
Largest extreme value |
data |
-ln(-ln(p)) |
Logistic |
data |
ln(p / (1 - p)) |
Loglogistic |
ln(data) |
ln(p / (1 - p)) |
3-parameter loglogistic |
ln(p / (1 - p)) |
where: |
data |
data value for the observation |
In(x) |
natural log of x |
value returned for p by the inverse cdf for the standard normal distribution. |
G-1(p), k |
value returned for p by the inverse cdf for a Gamma distribution with shape = k and scale = 1. Minitab uses the estimated shape parameter unless you enter a historical value. |
More |
If you plot data unadjusted for threshold, distribution fit is not indicated by a straight line. |
