Graph > Stem-and-Leaf
Use to examine the shape and spread of sample data. Minitab displays a stem-and-leaf plot in the Session window. The plot is similar to a histogram on its side, however, instead of bars, digits from the actual data values indicate the frequency of each bin (row).
Below is a stem-and-leaf plot for a data set with the following five values: 3, 4, 8, 8, and 10.
Stem-and-leaf of C1 N = 5
Leaf Unit = 1.0
1 0 3
2 0 4
2 0
(2) 0 88
1 1 0
The display has three columns:
In the example, the median for the sample is 8, so the count for the fourth row is enclosed in parentheses. The count for the second row represents the total number of observations in the first two rows.
Graph Variables: Enter one or more columns of data. Minitab displays a separate plot for each column.
By variable: Enter a column containing a grouping variable. The values in the By variable column must be integers between -10000 and +10000 or the missing data symbol (*). Minitab produces a separate plot for each group. This option does not work with the Trim outliers option.
Trim outliers: Check to trim all outliers and show them on special lines labeled LO and HI. This option does not work with the By variable option.
Increment: Enter a number to control vertical scaling by setting the increment between display lines (the difference between the smallest possible values on adjacent lines).
