Stat > Reliability/Survival > Accelerated Life Testing > Censor
Allows you to specify the censoring columns.
Use censoring columns: If you have right censored data, enter the censoring columns. The first censoring column is paired with the first data column, the second censoring column is paired with the second data column, and so on.
Censoring value: By default, Minitab uses the lowest value in the censoring column to indicate a censored observation. To use some other value, enter that value in Censoring value. Text values must be contained in double quotes.
