Stat > Reliability/Survival > Accelerated Life Testing > Results
You can control the display of Session window output.
Control the Display of Results
Display nothing: Choose to suppress all printed output, but do all requested storage and display graphs.
Response information, censoring information, regression table, log-likelihood, and goodness-of-fit: Choose to display the response and censoring information, the regression table, the log-likelihood, and goodness-of-fit measures.
In addition, table of percentiles, survival probabilities, list of factor level values and tests for terms with more than 1 degree of freedom: Choose to display the output described above, plus a table of percentiles and/or survival probabilities (if you requested them in Accelerated Life Testing - Estimate), list of factor level terms, and tests for terms with more than 1 degree of freedom.
Show log-likelihood for each iteration of algorithm: Check to display the log-likelihood at each iteration of the parameter estimation process.
