Stat > Reliability/Survival > Distribution Analysis (Right Censoring) or Distribution Analysis (Arbitrary Censoring) > Parametric Distribution Analysis > Test
Tests whether distribution parameters for a sample equal specified values, and whether two or more samples share the same shape, scale, location, or threshold parameters.
Minitab performs Wald Tests [7] and provides Bonferroni 95.0% confidence intervals for the following hypothesis tests:
Consistency of Sample with Value
Test shape (slope-Weibull) or scale (1/slope-other dists) equal to: Enter a test value to compare the sample's shape (Weibull) or scale (other distributions).
Test scale (Weibull or expo) or location (other dists) equal to: Enter a test value to compare the sample's scale (Weibull or exponential) or location (other distributions).
Test threshold equal to: Enter a test value to compare the sample's threshold.
Equality of Parameters
Test for equal shape (slope-Weibull) or scale (1/slope-other distributions): Check to test whether two or more samples have the same shape or scale.
Test for equal scale (Weibull or expo) or location (other distributions): Check to test whether two or more samples have the same scale or location.
Test for equal threshold: Check to test whether two or more samples have the same threshold.
For 2-parameter distributions, check the first two Equality of Parameters options to test whether two or more samples come from the same population. For 3-parameter distributions, check all Equality of Parameters options, to test the same. |
