Cumulative failure plots display the cumulative failure probabilities versus time. Each plot point represents the cumulative percentage of units failing at time t. The cumulative failure curve is surrounded by two outer lines - the approximate 95.0% confidence interval for the curve, which provide reasonable values for the "true" cumulative failure function.
