You must enter starting estimates or historical estimates for each distribution of failures each parameter you wish to estimate. Each variable, By variable group level, and failure mode represents a unique distribution that requires estimates in one single column or in separate columns. See the following table for various scenarios:
Variables with single failure modes:
Case |
Enter |
A single variable with a single failure mode. |
Two or more variables, each with a single failure mode. |
A By variable with several group levels. |
Variables with multiple failure modes:
Case |
Enter |
A single variable with a multiple failure modes. |
Two or more variables, each with multiple failure modes. |
A By variable with several group levels and multiple failure modes. |
Parameter estimates are assigned by failure mode then variable. Normally, the first column should contain the parameter estimates of failure mode 1, variable 1; the second column - parameter estimates of failure mode 1, variable 2, etc. If variable 2 does not have failure mode 1, the second column contains the parameter estimates of failure mode 2, variable 1.
Caution |
Do not enter starting estimates or historical estimates for failure modes that you have eliminated from the analysis. |
