Stat > Reliability/Survival > Distribution Analysis (Right Censoring) > Distribution ID Plot > Options
You can choose the method used to estimate the parameters. You can also estimate percentiles for specified percents, specify the x-axis minimum and maximum, and add your own title.
Estimation Method
Maximum Likelihood: Choose to estimate the distribution parameters using the maximum likelihood method, which are estimated by maximizing the likelihood function.
Least Squares (failure time(X) on rank(Y)): Choose to estimate the distribution parameters using the least squares (XY) method, which are estimated by fitting a regression line to the points in a probability plot.
Estimate percentiles for these percents: Enter the additional percents for which you want to estimate percentiles. You can enter individual percents (0 < P < 100) or a column of percents.
Handle tied failure times by plotting:
All points: Choose to plot the cumulative percents for each occurrence of a failure time.
Maximum of tied points: Choose to plot the maximum cumulative percent of identical failure times.
Average (median) of tied points: Choose to plot the median cumulative percent of identical failure times.
Show graphs of different variables or by levels: Choose to display the graphs overlaid on the same graph or on separate graphs.
Minimum and Maximum X Scale
Use default values: Choose to use the default values for the minimum and maximum X scale.
Use: Choose to enter your own values for the X scale minimum and maximum.
Minimum X scale: Enter a value for the minimum X scale.
Maximum X scale: Enter a value for the maximum X scale.
Title: To replace the default title, type the desired text in this box.
To change the method for calculating probability plot points, see Tools > Options > Individual Graphs > Probability Plots. |
