To make a distribution ID plot (uncensored/right-censored
data)
main topic see also
1 Choose Stat
> Reliability/Survival > Distribution Analysis (Right Censoring)
> Distribution ID Plot.
2 In Variables, enter the columns of failure
times. You can enter up to 50 columns (50 different samples).
3 If you have frequency columns,
enter the columns in Frequency
columns.
4 If all of the samples are stacked
in one column, check By
variable, and enter a column of grouping indicators in the
box.
5 Do one of the following:
· Choose
Use all distributions
to create probability plots for all eleven distributions.
· Choose
Specify
to create up to four probability plots with the distributions of your
choice.
If you have no censored values, you can skip steps 6
& 7. |
6 Click Censor.
7 Do one of the following, then
click OK.
· For
data with censoring columns: Choose Use censoring columns, then enter the censoring
columns in the box. The first censoring column is paired with the first
data column, the second censoring column is paired with the second data
column, and so on.
If you like, enter the value you use to indicate
censoring in Censoring
value. If you do not enter a value, Minitab uses the lowest
value in the censoring column.
· For
time censored data: Choose Time censor at, then enter a failure time
at which to begin censoring. For example, entering 500
says that any observation from 500 time units onward is considered censored.
· For
failure censored data: Choose Failure censor at, then enter a number
of failures at which to begin censoring. For example, entering 150
says to make all (ordered) observations starting with the 150th observation
censored, and all other observations uncensored.
8 If you like, use any of the
available dialog box options, then click OK.
