Minitab displays up to two goodness-of-fit statistics to help you compare the fit of distributions.
The Anderson-Darling statistic is a measure of how far the plot points fall from the fitted line in a probability plot. The statistic is a weighted squared distance from the plot points to the fitted line with larger weights in the tails of the distribution. Minitab uses an adjusted Anderson-Darling statistic, because the statistic changes when a different plot point method is used. A smaller Anderson-Darling statistic indicates that the distribution fits the data better.
The Pearson correlation measures the strength of the linear relationship between the X and Y variables on a probability plot. The correlation will range between 0 and 1, with higher values indicating a better fitting distribution.
