Use growth curves to analyze life data from a repairable system. A repairable system is one in which the parts are repaired instead of being replaced when they fail. For example, automotive engines are usually repaired many times before being replaced. System repair data usually consist of successive failure (or repair) times. However, data can also be measures such as distance from a reference point or the length of a crack.
Use nonparametric and parametric growth curves to determine whether a trend exists in times between successive failures of a repairable system; that is, to determine whether system failures are becoming more frequent, less frequent, or remaining constant. Use this information to make decisions concerning the future operation of your system, such as:
