Growth curves - interval data
Use a paired response of start and end times when your data are interval failure/retirement times.
Enter your data in table form, using Start and End columns:
·    Start - the time at the start of the interval.
·    End - the time at the end of the interval.
·    System - identifies each system within a sample. You do not need a system column when you have only one system.
·    Frequency (or Cost) - the total cost of repairs or total frequency of failures at a particular time. See Using cost or frequency columns for more information.
This data set illustrates interval data, as well as the use of a frequency column.
Start
End
System
Frequency (or Cost)
In this example,
·    Two failures occurred between 0 and 1 hours for system 1
·    Observation ceased on system 1 at 9 hours
When you have more than one sample, you can use separate columns for each sample. Alternatively, you can stack all the samples in one column, then set up a column of grouping indicators. For an illustration, see Stacked vs. Unstacked data.
Each sample is analyzed independently and results in one growth curve. All the samples display on a single plot, with different colors and symbols to help you compare reliability growth between samples.
For general information on repairable systems data, see Data - Growth Curves.
