Nonparametric Growth Curve - Storage
Stat > Reliability/Survival > Repairable System Analysis > Nonparametric Growth Curve > Storage
Use to store various characteristics of the nonparametric growth curve.
Enter number of levels in by variable: Enter the number of levels the column of grouping indicators contains. Use only if all of the samples are stacked in one column.
Individual curve
Mean cumulative function (MCF): Check to store the mean cumulative function.
Times for MCF: Check to store the times associated with the mean cumulative function.
Standard error of MCF: Check to store the standard error of the mean cumulative function.
Confidence limits for MCF: Check to store the confidence limits for the mean cumulative function. By default, Minitab stores the 95% confidence limits. You can change the confidence level in the Options subdialog box.
Difference in individual
Difference in mean cumulative function (MCF): Check to store the mean cumulative difference function.
Times for difference in MCF: Check to store the times associated with the mean cumulative difference function.
Standard error of difference in MCF: Check to store the standard error of the mean cumulative difference function.
Confidence limits for difference in MCF: Check to store the confidence limits for the mean cumulative difference function. By default, Minitab stores the 95% confidence limits. You can change the confidence level in the Options subdialog box.
