Stat > Reliability/Survival > Repairable System Analysis > Parametric Growth Curve > Estimate
Use to specify one of three estimation methods and either a power-law process or Poisson process model.
You can also enter a confidence level for Minitab to use for all confidence intervals.
Estimation method: Choose one of three estimation methods: maximum likelihood, conditional maximum likelihood, and least squares. See Estimation methods for parametric growth curves.
Power-Law process Choose to model the data using a Power-Law process. See Parametric growth curve models.
Estimate shape parameter: Choose to estimate the shape parameter from the data.
Set shape parameter: Choose to specify the shape value and enter a positive numeric constant.
Poisson process: Choose to model the data using a Poisson process. See Parametric growth curve models.
Confidence level: Enter a confidence level for all of the confidence intervals. The default is 95.0%.
Confidence intervals: Choose to use two-sided confidence intervals (the default) or just an upper or lower confidence bound.
