Stat > Reliability/Survival > Repairable System Analysis > Parametric Growth Curve > Storage
Use to store various characteristics of the parametric growth curve.
Enter number of levels in by variable: If all of the samples are stacked in one column, enter the number of levels the column of grouping indicators contains.
Mean cumulative function (MCF): Store the mean cumulative function evaluated at the corresponding time (exact data) or end time (interval data).
Confidence limits for MCF: Check to store the confidence limits for the mean cumulative function. By default, Minitab stores the 95% confidence limits. You can change the confidence level in the Estimate subdialog box.
Failure rate (ROCOF): Check to store the ROCOF evaluated at the corresponding time (exact data) or end time (interval data).
Confidence limits for ROCOF: Check to store the confidence limits for the ROCOF. By default, Minitab stores the 95% confidence limits. You can change the confidence level in the Estimate subdialog box.
Parameter estimates: Check to store estimates of the shape and scale.
Standard error of estimates: Check to store the standard errors of the shape and scale where available.
Confidence limits for parameters: Check to store the confidence limits for the shape and scale. By default, Minitab stores the 95% confidence limits. You can change the confidence level in the Estimate subdialog box.
