Stat > Reliability/Survival > Probit Analysis > Results
You can control the display of Session window output.
Control the Display of Results Choose one of the options below to control display of Session window output.
Display nothing Choose to suppress display of the results.
Response information, regression table, test for equal slopes, log-likelihood, multiple DF test and 2 goodness-of-fit tests Choose to display information about the response, the regression table, the test for equal slopes (if the model contains a factor), the log-likelihood, the multiple degree of freedom test (if the model contains a factor with more than two levels), and the Pearson and Deviance goodness-of-fit tests.
In addition, distribution parameter estimates, table of percentiles and survival probabilities: Choose to display the distribution parameter estimates, table of percentiles and/or survival probabilities (if requested in Probit Analysis - Estimate).
In addition, characteristic of distribution and the Hosmer-Lemeshow goodness-of-fit test: You must choose this option in order to see the results of the Hosmer-Lemeshow test.
Show log-likelihood for each iteration of algorithm: Check to display the log-likelihood at each iteration of the parameter estimation process.
