Stat > Reliability/Survival > Probit Analysis > Storage
You can store the Pearson and deviance residuals, characteristics of the fitted distribution, and information on the estimated equation.
Enter number of levels in factor variable: If all of the samples are stacked in one column, enter the number of levels the column of grouping indicators contains.
Residuals Choose to store one or both of the residual types below:
Pearson
Deviance
Characteristics of Fitted Distribution Choose to store any of the fitted distribution characteristics below:
Percentiles: Check to store the percentiles.
Percents for percentiles: Check to store the percents associated with the percentiles.
Standard error of percentiles: Check to store the standard error of the percentiles.
Confidence limits for percentiles: Check to store the limits of the confidence intervals for the percentiles.
Stress for probabilities: Check to store the stress for survival probabilities or cumulative failure probabilities.
Survival probabilities: Check to store the survival probabilities.
Confidence limits for survival probabilities: Check to store the confidence limits for survival probabilities.
Cumulative failure probabilities: Check to store the cumulative failure probabilities.
Confidence limits for cumulative failure probabilities: Check to store the confidence limits for cumulative failure probabilities.
Information on Estimated Equation Choose to store any of the information on the estimated equation below:
Event probability: Check to store the event probability.
Estimated coefficients: Check to store the estimated coefficients.
Standard error of estimates: Check to store the standard error of the estimated coefficients.
Variance/covariance matrix: Check to store the variance/covariance matrix for the estimated coefficients.
Natural response rate: Check to store the natural response rate.
Standard error of natural response: Check to store the standard error of the natural response rate.
Log-likelihood for last iteration: Check to store the log-likelihood for the last iteration.
