You can enter numeric, text, or date/time factor levels. Minitab assigns one factor level to be the reference level, meaning that the estimated coefficients are interpreted relative to this level.
Regression with Life Data creates a set of design variables for each factor in the model. If there are k levels, there will be k - 1 design variables and the reference level will be coded as 0. Here are two examples of the default coding scheme:
Factor A with 4 levels |
Factor B with 3 levels |
(1 2 3 4) |
(High Low Medium) |
reference |
1 2 3 4 |
A1 0 1 0 0 |
A2 0 0 1 0 |
A3 0 0 0 1 |
reference |
High Low Medium |
B1 0 1 0 |
B2 0 0 1
By default, Minitab designates the lowest numeric, date/time, or text value as the reference factor level. If you like, you can change this reference value in the Options subdialog box.
