You can fit models with:
Here are some examples. A is a factor and X is a covariate.
Model Terms |
A X A*X |
Fits a full model with a covariate crossed with a factor |
A | X |
An alternative way to specify the previous model |
A X X*X |
Fits a model with a covariate crossed with itself making a squared term |
A X(A) |
Fits a model with a covariate nested within a factor |
This model is a generalization of the model used in Minitab's general linear model (GLM) procedure. Any model fit by GLM can also be fit by the life data procedures. For a general discussion of specifying models, see Specifying the model terms and Specifying reduced models. In the regression with life data commands, Minitab assumes any variable in the model is a covariate unless the variable is specified as a factor. In contrast, GLM assumes any variable in the model is a factor unless the variable is specified as a covariate.
Life data models in Minitab have the same restrictions as general linear models:
