Use the table below to choose between a 0-failure and an m-failure test.
A 0-failure test... |
An m-failure test (m > 0)... |
Usually reduces total test time for highly reliable items. |
May reduce total test time if you can run the tests sequentially. For example, if you are testing 3 units in a 1-failure test and the first 2 units pass, you do not have to test the third. |
Is more practical when failures are unlikely in a reasonable amount of time. |
May not be feasible for highly reliable units. |
Does not let you check the assumptions of the test design. |
Allows you to check the assumptions of the test design. |
Does not make sense when you are likely to have at least one failure. |
Has a better chance of passing than a 0-failure test when you have a marginally improved design. |
