Stat > Reliability/Survival > Test Plans > Accelerated Life Testing > Options
You can assume a known shape or scale parameter.
You can also enter a confidence level that Minitab will use for all confidence intervals.
Assume shape (Weibull) or scale (other distributions) is known: Check if you know the shape (Weibull) or scale (other distributions) parameter. This results in a smaller sample size because Minitab assumes that you do not need to estimate this parameter. For the exponential distribution, Minitab assumes a Weibull distribution with shape parameter of one, which is equivalent to an exponential distribution.
Confidence level: Enter the confidence level. The default is 95.0.
Confidence interval: Choose to use one-sided confidence intervals (the default) or two-sided confidence intervals. Use a one-sided confidence interval when you are only interested in either an upper bound or a lower bound on what you are trying to estimate.
