The precision is based on the width of the confidence interval for the parameter you are estimating. The wider your confidence interval, the fewer units you need to test. By default, Minitab calculates a one-sided confidence interval, so the width only affects the distance between the estimate and the lower or upper bound. You can request a two-sided confidence interval in the Options subdialog box.
For example, if you want to estimate the 10th percentile of your failure time distribution, and the lower bound is to be no more than 25 hours less than your estimate, choose Lower bound and enter 25 as your desired precision in Sample sizes or precisions as distances from bound of CI to estimate.
You may want to enter a range of values for the precision, to see its impact on your sample size.
