Stat > Reliability/Survival > Test Plans > Demonstration > Graphs
Use to draw a POP (probability of passing) graph to assist you in choosing a minimum value for the parameter you want to demonstrate.
Probability of passing the demonstration test: Check to display a POP graph.
Show different sample sizes/testing times overlaid on the same page: Choose to display different sample sizes or testing times overlaid on the same page.
Show different test plans overlaid on the same page: Choose to display different test plans overlaid on the same page.
Minimum X scale: Enter a value for the minimum x-axis scale.
Maximum X scale: Enter a value for the maximum x-axis scale.
