The reliability goal for a turbine engine combustor is a 1 percentile of at least 2000 cycles. The number of cycles to failure tends to follow a Weibull distribution with shape = 3. You can accumulate up to 8000 test cycles on each combustor. You must determine the number of combustors needed to demonstrate the reliability goal using a 1-failure test plan.
1 Choose Stat > Reliability/Survival > Test Plans > Demonstration.
2 Choose Percentile, then enter 2000. In Percent, enter 1.
3 In Maximum number of failures allowed, enter 1.
4 Choose Testing times for each unit, then enter 8000.
5 From Distribution, choose Weibull. In Shape (Weibull) or scale (other dists), enter 3. Click OK.
Session window output
Demonstration Test Plans
Reliability Test Plan Distribution: Weibull, Shape = 3 Percentile Goal = 2000, Target Confidence Level = 95%
Actual Failure Testing Sample Confidence Test Time Size Level 1 8000 8 95.2122 |
Graph window output
You must test 8 combustors for 8000 cycles to demonstrate with 95.2% confidence that the first percentile is at least 2000 cycles.
The graph shows the likelihood of actually passing the test that you specified. Here,
