Pre-fixed Ranges and Default Steps
Minitab chooses the pre-fixed ranges for the proportionate allocation
of test units based on the following criteria:
· More
test units are assigned to the lowest test stress.
· Either
a large or small number of test units exists at the middle stresses.
· The
proportionate allocation of units at a test stress is not too small relative
to the others.
The ranges change as the number of stresses change:
· For
a two-stress design, the ranges for the proportions at the lowest and
highest test stress are RL
= [0.05, 0.85] and RH
= [0.075, 0.5], respectively.
· For
a three-stress design, the lowest test stress range is RL
= [0.333, 0.683]. The other test stresses have a common range of R = [0.040,
0.333].
· In
general, if your design has K test stresses, the range for the proportions
at the
lowest
test stress is RL
= [1/K, 1/K + 0.35]
middle
stresses is R = [(1- 1/K - 0.350)/2K,
1/K]
highest
test stress is R = [(1- 1/K - 0.350)/2K,
1/K] and chosen so that the complete set of proportionate allocations
sums to one
