Searching for the Optimum Proportions
The most efficient plan is only the most efficient in the specified
search space. Minitab can find the most efficient or "optimum"
allocation of test units in two ways:
· You specify
the search space as a finite set or sets of proportions. Each column represents
a different test plan. Minitab ranks those test plans according to their
efficiency.
· Minitab
searches for the optimum proportions in ranges. That is, Minitab uses
a step to go from one candidate group of proportions to another. The default
step length is 0.05, but you can increase or reduce the length.
