1 Choose Stat > Reliability/Survival > Test Plans > Demonstration.
2 Under Minimum Value to be Demonstrated, choose one of the following:
3 In Maximum number of failures allowed, enter a number greater than or equal to zero. See m-failure test plan.
4 Under Specify values for one of the following, choose either:
Each combination of maximum number of failures allowed and sample size or testing time will result in one test plan. You may wish to request several test plans and compare the results. |
5 Under Distribution Assumptions, choose any distribution from Distribution. Then, enter an estimate of the shape or scale in Shape (Weibull) or scale (other dists). See estimating the shape or scale.
6 If you like, use any dialog box options, then click OK.
