Stat > Reliability/Survival > Warranty Analysis > Warranty Prediction > Graphs
You can display the predicted number of failures.
Predicted number of failures plot: Check to display a plot of the predicted number of failures.
Predicted cost of failures plot: Check to display a plot of the predicted cost of failures. This option is only available if you specify an optional Average cost per failure in the main dialog box.
Display confidence intervals on plot: Check to display confidence intervals on the predicted number of failures plot and predicted cost of failures plot.
