The Six Sigma Process Report works with data in subgroups or with individual observations.
You can structure your subgroup data down a column or across rows. Here is the same data set, with subgroups of size 5, structured both ways:
C1 |
C1 |
C2 |
C3 |
C4 |
C5 |
40.13 |
40.13 |
39.68 |
40.84 |
41.52 |
40.02 |
39.68 |
39.54 |
39.87 |
40.25 |
40.47 |
41.41 |
40.84 |
39.64 |
37.36 |
39.20 |
38.72 |
39.39 |
41.52 |
39.15 |
41.15 |
39.96 |
40.48 |
40.05 |
40.02 |
39.54 |
39.87 |
40.25 |
40.47 |
41.41 |
39.20 |
38.72 |
39.39 |
and so on |
Note that the first five observations (subgroup 1) in the left-side data set are the first row of the right-side data set, the second five observations (subgroup 2) are across the second row, and so on.
The way you specify data columns in the Six Sigma Process Report dialog box depends on the structure of your worksheet, as described below.
Under Data are arranged as, click Subgroups across rows of and enter the data columns.
- Individual observations
Under Data are arranged as, click Single column and enter a data column in the text box. Enter 1 in the Subgroup size text box.
- Same-size subgroups
Under Data are arranged as, click Single column and enter a data column in the text box. Then enter the subgroup size in the Subgroup size text box.
- Unequal-size subgroups
When subgroups are of unequal size, you must structure your data in a column, then create a second column of subscripts which serve as subgroup indicators. Each time a subscript changes, a new subgroup begins. In the following example, C1 contains the data and C2 contains the subgroup indicators:
C1 |
C2 |
39.68 |
1 |
40.84 |
1 |
41.52 |
1 |
40.02 |
2 |
39.54 |
2 |
39.87 |
2 |
40.25 |
2 |
40.47 |
2 |
41.41 |
2 |
39.20 |
3 |
38.72 |
3 |
39.39 |
3 |
and so on |
Subgroup 1 has 3 observations, subgroup 2 has 6 observations, and so on.
To specify the data in the dialog box: Under Data are arranged as, click Single column and enter a data column in the text box. Enter a subscript column in the Subgroup size text box.
