See the notation used in the equations below:
Calculate adjusted means as:
madj,i = mi + qimPool
where q i = |
If you do not specify mean shift factors, the mean pool = 0.
Calculate adjusted standard deviations as:
s2adj,i = s2i + ris2Pool
where r i = |
If you do not specify variation expansion factors and you do not specify both gap specification limits, the variance pool = 0.
