See the notation used in the equations below:
mGap,ST |
S madj,i Ci Vi Ni |
Short-term gap mean after allocation |
sGap,ST |
Short-term gap standard deviation after allocation |
Z.LSL(ST) |
(T- LSL) / sGap,ST |
If only lower specification on the assembly gap is given If only upper specification in the assembly gap is given If neither lower nor upper specification in the assembly gap |
Z.USL(ST) |
(USL- T) / sGap,ST |
If only upper specification on the assembly gap is given Otherwise |
Z.BenchGap,ST |
F-1(F(Z.USL(ST)) - (F(-Z.LSL(ST))) Z.USL(ST) Z.LSL(ST) |
If neither lower nor upper specification in the assembly gap If only upper specification in the assembly gap is given Otherwise |
For corresponding calculations for short-term statistics, see Determining the gap distribution after allocation of the pools (long-term statistics).
