To perform an analysis of means
1    Choose Stat > ANOVA > Analysis of Means.
2    In Response, enter a numeric column containing the response variable.
3    Under Distribution of Data, choose Normal, Binomial, or Poisson.
·    If you choose Normal, you can analyze either a one-way or two-way design. For a one-way design, enter the column containing the factor levels in Factor 1. For a two-way design, enter the columns containing the factor levels in Factor 1 and Factor 2.
·    If you choose Binomial, type a number in Sample size.
4    If you like, use one or more of the dialog box options, then click OK.
