Stat > ANOVA > General Linear Model > Fit General Linear Model > Results
Control the level of detail in the display of output to the Session window.
Display of results: Choose the level of detail to display.
Simple tables: Choose to display the simpler versions of all tables.
Expanded tables: Choose to display the expanded versions of the ANOVA, Coefficients, Model summary, and Fits and Diagnostics tables.
Method: Check to display a table that summarizes non-default settings.
Factor information: Check to display a summary of the factor names, number of levels, and level values.
Analysis of variance: Check to display the ANOVA table that includes the sums of squares by source and the p-values.
Model summary: Check to display statistics that evaluate model fit, including R2.
Coefficients: Check to display the coefficients, effects, and p-values. The drop-down list allows you to control how many coefficients for factors are in the table.
Default coefficients: Choose to display all linearly independent coefficients of the factors.
Full set of coefficients: Choose to display coefficients for all levels of the factors, which includes the final, linearly dependent, level.
Regression equation: Check to display the regression equation(s). The drop-down list allows you to control how many equations are displayed.
Separate equation for each set of factor levels: Choose to display a separate equation for each combination of factor levels.
Single equation: Choose to display one equation that includes all levels of all factors.
Fits and diagnostics: Check to display fits and diagnostics.
Only for unusual observations: Choose to display fits and diagnostics for only the unusual observations.
For all observations: Choose to display fits and diagnostics for all observations.
Expected mean squares and error terms for tests: Check to display the error terms that are used in each F-test for a model that contains random terms.
Variance components: Check to display the variance component estimates for random terms.
Means: Check to display the least squares means that you specified in the Options dialog.
