Restrictions for General Linear Models
If your general linear model includes nested factors or random factors,
or if it uses binary coding, the following are restrictions on the procedures
that you can perform.
· If your model
contains random factors, you must specify a hierarchical model in the
Model dialog.
· Stepwise
procedures are not available for models that contain random factors.
· Comparisons
are not available for terms that contain or interact with random factors.
Nesting is a form of interaction. Suppose the model contains A B C A*B,
where both A and C are random, and B is fixed. Because A*B is a term in
the model, no multiple comparison results for B are available even though
B is a fixed factor. However, if the model does not include A*B, multiple
comparison results are available for B.
There is a special case for a balanced design that has
two factors. Suppose the model contains A B A*B, where A is random, and
B is fixed. Even though A*B is in the model, you can perform multiple
comparisons for B.
· Comparisons
is disabled if you choose (1,
0) coding and the model is non-hierarchical. To enable Comparisons
for this case, choose (-1,
0, +1) coding or specify a hierarchical model.
· Factorial
plots cannot display nested factors.
· Predict
cannot calculate confidence intervals when the model contains random factors.
· Predict
is not available for models that contain nested factors.
· Response
Optimizer is not available for models
