General MANOVA - Graphs
Stat > ANOVA > General MANOVA > Graphs
Displays residual plots. You do not have to store the residuals and fits in order to produce these plots.
Residuals for Plots: You can specify the type of residual to display on the residual plots.
Regular: Choose to plot the regular or raw residuals.
Standardized: Choose to plot the standardized residuals.
Deleted: Choose to plot the Studentized deleted residuals.
Residual Plots
Histogram of residuals: Check to display a histogram of the residuals.
Normal plot of residuals: Check to display a normal probability plot of the residuals.
Residuals versus order: Check to plot the residuals versus the order of the data. The row number for each data point is shown on the x-axis--for example, 1 2 3 4... n.
Residuals versus the variables: Enter one or more columns containing the variables against which you want to plot the residuals. Minitab displays a separate graph for each column.
